Im have installed Salamander on Windows 7 and I want to use TortoiseSVN. If I use windows explorer everything works normal. Folder icons have that small icon from SVN in it and when I open context menu I can find all posible options and buttons for SVN. But if I use salamander then there are no icons from svn and there is no SVN in context menu.
Can this be repaired?
Windows 7 - folder icons and context menu
Re: Windows 7 - folder icons and context menu
Hi, please look at http://tortoisesvn.tigris.org/faq.html#nomenus
Altap Salamander is 32b application so you need the 32b version of TSVN.
Note: we plan to build also 64b version of Salamander.
Ok thank you very much.
