UnCHM function problem
thomas
Post by thomas »
if I understand it correctly the UnCHM should work like the other unpacker such as UnRAR, UnARJ, UnLHA ...
But you can't browse in to the CHM files like in other archives with the other packer plugins. The CHM files open directly as usual, it would be nice if salamander would be handle these CHM files like the other archives.
Best regards,
Thomas
Re: UnCHM function problem
Hi Thomas, please open Options > Configuration > Archivers > Archivers associations in Panels and add new item:
File Extension: CHM
List and Unpack: UnCHM (Plugin)
Delete and Pack: -- not supported --
We decided to not associate UnCHM plugin this way because it will prevent users from displaying HTML help.
You will need to open context menu and choose the Open command.
thomas
Post by thomas »
Hello Jan,
thank you for the declaration, it works perfectly.
