Search results and Make File List
kilpatrickp
It would be nice if you could use the "Make File List" functionality available on a search screen. I often do a search, and need to get the names of the found files out for a listing, but there doesn't seem to be any way to take them all, and one at a time is a bit of a problem for large sets.
Re: Search results and Make File List
Try this in the meantime: File list export from Find Files & Directories
