Dear all,
I am a long-time user of SS and I have recently bought a license.
I would like to see the number of hot paths (the shortcuts to certain directories, located above the tree pane window) rise to 15 or 20. The current limit is 10 and that is not sufficient I am afraid - contemporary HDD are quite big with a complicated directory structure, and I have to always leave something out in order to keep the number at 10.
I hope my suggestion will be taken into consideration for future versions of SS. I will be very easy to implement!
Sincerely,
More hot path positions needed
Re: More hot path positions needed
Hi Pavel, thank you for this idea, we will definitely consider it, because it is frequently requested feature.
