![Smile :)](./images/smilies/icon_smile.gif)
Follow these steps: configuration -> editors
create new insert (*.txt), you will see arguments "$(Name)"
Delete the argument and choose Name in the menu on the rightside. Now you will see $(Name) without quotes.
After this open some txt files using the external editor. I found out that some txt files were blank in the external editor. If the arguments contain the quotes it seems to work fine.
I want to know if you guys can find some txt files displaying nothing.
