Autostart in minimized mode
J Hair
Post by J Hair »
I use Servant Salamander several times a day. It's an AWESOME tool and the word is spreading as people see me using it.
Since I always end up using it, I'd like to have it autostarted but minimized. To autostart, I can just place it in the Startup folder. But I'd like to have it minimized as I don't use it first.
Thanx,
jsh
ino
Re: Autostart in minimized mode
Post by ino »
J Hair wrote: But I'd like to have it minimized as I don't use it first.
:idea:
Start your Salamander Image with following js script:
- open folder where is Salamander Image installed
- press SHIFT + F4
- change the new file extension from .txt to .js
- copy & paste following 3 lines in it
- and save it.
var wss  = WScript.CreateObject("WScript.Shell");
wss.run ("SALAMAND.exe",6);
WScript.Quit();
J Hair wrote:Since I always end up using it, I'd like to have it autostarted but minimized. To autostart, I can just place it in the Startup folder. But I'd like to have it minimized as I don't use it first.
Right click the Servant Salamander icon, choose the Properties command. In the Run box choose the Minimized option.
KNUT
Post by KNUT »
ino wrote:Start your Salamander with following js script:[...]
He breaks a butterfly on the wheel :D :roll:
Kind regards, KNUT
