Quick view
Quick view
I am new with Salamander and wandering if this file manager has 'quick view' option: option to see the contest of the selected file at the opposite panel instead of opening separate window.
Can you help me to find this option?
Yes, please look at Altap Roadmap.
Thank youJan Rysavy wrote:Yes, please look at Altap Roadmap.
Re: Quick view
Perhaps another tool can help you: TextviewDworkin wrote:I am new with Salamander and wandering if this file manager has 'quick view' option: option to see the contest of the selected file at the opposite panel instead of opening separate window. Can you help me to find this option?
Kind regards, KNUT
Re: Quick view
Thank you for the linkKNUT wrote:Perhaps another tool can help you: Textview
But I would rather prefer to have one tool for file managing than a small zoo of different programs.
Quick view is a standard feature in other Salamander's competitor and I was wondering where it is in this product.
Lack of "Quickview" feature is reason to not use AS.
This is a very important feature that is missing from AS. It should not be a low priority item. Esp. with all the digital cameras people use, etc., makes it very important.
Just so you know.
Just so you know.
There are other (and better) ways than the Quick View feature *. You can set Thumbnail View to see thumbnails in the panel. And if you want to see the pictures in full screen, just open the first one in the Viewer and then tap Space (on the keyboardMitchell wrote:Esp. with all the digital cameras people use, etc., makes it very important.
*] For pictures, I mean.
