FTP Client Plugin to preserve file date/time
Kontarsky
FTP Plugin - Keep Remote File Date/Time
An option in the FTP Client Plugin to preserve file date/time when transferring file from remote host is badly needed.
Kontarsky
Kontarsky
I took your suggestion and tried with the server at ftp.altap.cz. To my surprise, it worked perfectly, preserving all file dates and times. Clearly the problem isn't with the plugin, but rather with my server and it's interaction with my system. I'll contact my hosting company and figure out the problem with them. I'm sorry for causing you the unnecessary work.
I very much appreciate your help with this matter.
Thank you very much.
I guess that this problem is based on wrong parsing of listings from your FTP server. Date&time is not properly read, so it cannot be set to target files. I need more info about FTP server to solve this problem. If you can send me at least some raw listing: right click in panel, choose Show Raw Listing, then click Save As and email me saved file (list some directory without sensitive data), my email is petr.solin@altap.cz.
