Windows Mobile System File Access
drkstoner
Post by drkstoner »
I am trying out Salamander in hope to find a faster way to copy files from \windows\system\dumpfiles\ directory on windows mobile phone without have to install anything like total commander on the device but with your software I get an access denied message same as I get with total comander for windows using the mobilece plugin is it just impossible to copy files without using a program installed on the phone or am I missing some piece of info to do this? the main reason for this is I work for a Dev company with multiple chipsets and builds and when I find a bug that crashes a phone I would like to be able to just grab the logs without wasting alot of time trying to recreate it
Hello, unfortunately we have no idea :(
AndrewSh
Post by AndrewSh »
drkstoner, it's nothing to do with the mobile plugin. Normally it will never give you the access to system or ROM files. If you wanna cheat the plugin - just rename the dump and reboot device - it will help you to grab the file.
Unfortunately - I can not check it - I never switch on Error report on my mobile device. But it should work.
Other way - Resco file explorer (from 2008 v7.02) now provides full access to system and ROM files - try it to copy your dump to another destination and then grab it with Salamander.
