While upgrading form b10 to b11 I lost all of my FTP bookmarks. They ara still available in the registry, b10 branch, but the format of the configuration has changed.
Any chance to recover from that?
FTP settings lost
Re: FTP settings lost
Did you import 2.5b10 configuration when you started 2.5b11 for the first time?neil.young wrote:While upgrading form b10 to b11 I lost all of my FTP bookmarks. They ara still available in the registry, b10 branch, but the format of the configuration has changed.
How to import 2.5b10 configuration again:
1) exit all instances of Servant Salamander
2) using RegEdit.exe (part of Windows) delete HKEY_CURRENT_USER\Software\Altap\Servant Salamander 2.5 beta 11
3) start SS 2.5b11 and let it import old configuration from 2.5b10
Please let me know.
Guest
I doesn't matter if the previous version is running or not. When the old configuration is found in your Registry, it will be (default behaviour) imported when you start a new version of Servant Salamander.Anonymous wrote:Probably caused by an open b10 while installing b11?
Indeed, there could be something broken.
