I'm using the Windows Offline files feature to sync some work files and stumbled over an issue with Altap Salamander;
I marked a folder and it's sub folders for offline use, but decided that the .svn sub folder (used by Subversion) isn't needed so I unmarked them. But when I browse the folder using AS the sync overlay icon returns and the folder is marked as available offline. When browsing with explorer the offline status is correct until i view the folder with AS. I also noticed that if I unselect the "Make Available offline" form AS the popup asking if I no longer want to have the files available, but nothing seems to happen.
I can live with having to use Explorer for making files available offline, but AS reapplying settings I've turned off is no good..
Offline files issue
