Hi
What's the best way to do drag and drop copy operations from one pane to the other when the panels are set to use Full Row Select? I can't seem to find a safe place to 'drop' the file except in the blank spot way at the bottom of the file list. If I drop it on a highlighted item it tries to launch the selected file instead.
Thanks
John
Copy using drag and drop with Full Row Select enabled
Re: Copy using drag and drop with Full Row Select enabled
I use the scroll bar as a safe place to drop filesjohnd126 wrote:I can't seem to find a safe place to 'drop' the file
Hey, both those ideas rock! Thanks!ino wrote:I use the scroll bar as a safe place to drop filesjohnd126 wrote:I can't seem to find a safe place to 'drop' the fileor better use F5 or F6
