More Hot Paths
More Hot Paths
I would be great, if I could define more than 10 hot paths.
Doesn't matter if I there are assigned Hot Keys, but the path should be shown in drop down 'Change Drive' Menu.
Thanks
Thanks
Re: More Hot Paths
Have you checked http://www.altap.cz/salam_en/newver.html ???Eric wrote:I would be great, if I could define more than 10 hot paths.
Thanks
- Structured and unlimited Hot Paths.
SelfMan,
I spent 15 minutes trying to figure out how to make a customized user menu that would allow to move to a specified directory, but couldn't figure it out. I tried searching the discussion for an example, but couldn't find one.
Could you please explain a bit more how to do this or post an example?
Thanks,
Rich
Thanks,
Rich
I am using this script (e.g. d:\tools\salhotmenu.vbs):
and create user menu entries like this:
Command: d:\tools\salhotmenu.vbs
Arguments: "\\Server1\Share11"
Initial directory: $(SalDir)
Execute through shell: unchecked
Show item in User Menu Bar: checked
Set objArgs = WScript.Arguments
Set sh = WScript.CreateObject("WScript.Shell")
bFound = sh.AppActivate("Salamander 2.5")
if bfound then
sh.SendKeys "+{F7}"
sh.SendKeys objArgs(0) & "{ENTER}"
end if
Re: More Hot Paths
So how to have "unlimited" hot paths? please explain..
Does not work for me on Windows 10 Pro and Salamander 4.0 (run as Admin).
Re: More Hot Paths
The script does work, after a minor modification
32bit Salamander
64bit Salamander
the AppActivate must contain the proper application title.
32bit Salamander
bFound = sh.AppActivate("Altap Salamander 4.0 (x86)")
if bfound then
sh.SendKeys "+{F7}"
end ifCode: Select all
bFound = sh.AppActivate("Altap Salamander 4.0 (x64)")
if bfound then
sh.SendKeys "+{F7}"
end if
