I have the following problem:
When I delete a file using DEL (into the Rec. bin) and then empty the Rec. bin, I can UDELETE the file without any problem.
But when I delete a file using Shift+DEL (bypassing the Rec. bin), I am not able to UNDELETE the file correctly (the original and the new file differ.)
What could be the problem?
Undeleting files problem
Please look at http://www.altap.cz/salam_en/help/undel ... _intro.htm
Try to avoid writing data to your volume (try for example delete and recover file from your USB stick).
Btw, what does the Condition column say about your file?
guest
So it looks like other process is writing to your local disk...
You can use SysInternal's FileMon to monitor disk access.
