uninstalled, but cant delete salamext.dll
chimpoo
Post by chimpoo »
i uninstalled the program because i had no need for it anymore
but
it left behind a folder named plugins
inside is salamext.dll
i tried to delete it, wouldnt work
i restarted comp many times
and tried deleting it without having explorer.exe running
nothing
please
someone help
btw, this product is good other than that
Hello, it looks like uninstaller didn't unregister the shell extension. How Did you unistall Salamander?
Workaround:
1. unregister salamext.dll shell extenstion using command: regsvr32 /u salamext.dll
2. rename salamext.dll to (for example) salamext._dll.
3. restart Windows
4. delete salamext._dll
Guest
Post by Guest »
thanks man
ill try that right now
and i uninstalled through the add and remove programs
Jan Rysavy wrote:Hello, it looks like uninstaller didn't unregister the shell extension. How Did you unistall Salamander?
Workaround:
3. restart Windows
Shouldn't you unregister the Shell extension manualy before removing it? Manual uninstallation: regsvr32 /u salamext.dll
zarevak wrote:Manual uninstallation: regsvr32 /u salamext.dll
I will update my post, thank you!
