File Comparator: export results
Posted: 28 Jun 2012, 13:45
Was thinking it would be nice to be able to export the results, perhaps to html (which could handle colorizing) & or diff or ...
Often you (I) would like to show a diff to others, but the only (semi) convenient way is to use a scrolling screen capture utility (FSCapture works) but its output formats are as a picture or PDF.
If you could export results to diff or html, you could then post as "text" either in a forum or places like pastebin.
