File Comparator: export results
Was thinking it would be nice to be able to export the results, perhaps to html (which could handle colorizing) & or diff or ...
Often you (I) would like to show a diff to others, but the only (semi) convenient way is to use a scrolling screen capture utility (FSCapture works) but its output formats are as a picture or PDF.
If you could export results to diff or html, you could then post as "text" either in a forum or places like pastebin.
Re: File Comparator: export results
Bump.
It might only be needed once every two years or so, but it sure would be useful.
xm
Post by xm »
+1
for me even the simple text output like fileoffset-bytes1/chars1-bytes2/chars2 etc. is beneficial for saving, thanks
