the specified server cannot perform the requested operation
Jorgensen
Post by Jorgensen » 06 Aug 2018, 21:20
Hi
I'm trying to copy some files from my macbook to my windows 10 computer using salamander.
When i try i get this error "(58) the specified server cannot perform the requested operation".
I can cut the files in salamander, and then paste them using file explorer, but i really like servant salamander and would also like to use it for this operation.
Is there somekind of plugin i need or is it just not possible?
Jorgensen
Re: the specified server cannot perform the requested operation
Post by tukanos » 07 Aug 2018, 10:00
How do you interconnect (what protocol) macbook with windows 10?
Post by therube » 07 Aug 2018, 11:57
An old thread, but may it holds something, "Not enough storage is available to process this command."
Jorgensen
Post by Jorgensen » 07 Aug 2018, 19:58
Hi tukanos
i'm not sure what protocol i use - i simply shared the folder, went into net:\ and it lists my macbook.
strange i can
- copy a file from my windows pc to the mac, with salamander
- i can copy the same file back again, with salamander
- i can play i *.mov direct from the shared folder on the mac
- but i can't copy or move the *.mov file to my pc via salamander, only via file expolerer
i tried to run salamander as administrator, but that did not change anything.
can it be something with somekind of rights that salamander does not have?
Jorgensen
Post by SelfMan » 08 Aug 2018, 16:12
Do the files you want to copy have any accented characters? like ä, ô, ň, š, č etc.
Jorgensen
Post by Jorgensen » 12 Aug 2018, 13:14
Hi selfman
nope - no special characters used.
Jorgensen
Post by SelfMan » 12 Aug 2018, 13:57
juts for a test, can you rename a file to something like 1.mov and then try to copy it?
