Command: net use l: \\<resourcename>\share1 *)
Arguments: empty
Initial directory: C:\Temp
Options: [x] Execute through shell
Command prompt returns error: The network name cannot be found.
*) <resourcename> is existing > e.g. when pinged from command prompt it responses (and the net use command also works in Total Commander
Is there something wrong in my "Salamander" Command syntax or where?
//timo
