Usermenu command produces an error
tjsuominen
Post by tjsuominen »
I try to create some User menu command and the first problem arise with simple "net use" command:
Command: net use l: \\<resourcename>\share1 *)
Arguments: empty
Initial directory: C:\Temp
Options: [x] Execute through shell
Command prompt returns error: The network name cannot be found.
*) <resourcename> is existing > e.g. when pinged from command prompt it responses (and the net use command also works in Total Commander ;))
Is there something wrong in my "Salamander" Command syntax or where?
//timo
Re: Usermenu command produces an error
Hi //timo
I recommend you do not provide parameters in the command text box.
I suppose what happens is that your double backslash is reduced to one backslash somewhere along the processing sequence.
Tick [x] Open shell window
Untick [ ] Close shell window
to verify
This does not happen if you specify the parameters in the Arguments text box.
tjsuominen
[Solved] Usermenu command produces an error
That did the trick, working as expected.
Appreciated & thx :)
//timo
