Ful path too long. Really?
crystalidea
Post by crystalidea »
Why can't I delete a long path? Windows Explorer is able to do that. Do you use MAX_PATH?
Have to open Windows Explorer to delete a folder :cry:
Error
Name "testing_6_automating_with_continuous_integration.html" with full path is too long.
Path: C:\Xcode_6_extracted\Xcode.app\Contents\Developer\Documentation\DocSets\com.apple.adc.documentation.Xcode.docset\Contents\Resources\Documents\documentation\DeveloperTools\Conceptual\testing_with_xcode\testing_6_automating_with_continuous_integration
[Skip] [Skip All] [Cancel]
Re: Ful path too long. Really?
249 characters, so you're right around the limit.
Oh, 254 characters with .html tacked on.
While Windows Explorer may work, not all Windows utilities will.
Perhaps (or something like):
Everything uses SHFileOperation to delete files.
SHFileOperation is limited to 260 characters.
What Everything should do for a future release is check if SHFileOperation fails and try DeleteFile/RemoveDirectory...
http://www.voidtools.com/forum/viewtopi ... 388#p10636
crystalidea
Got it. It's because DeleteFileA is limited to MAX_PATH
DeleteFileW is able to use 32,767 characters.
2015 year and no unicode :( :( :(
-=Majkl=-
Post by -=Majkl=- »
AS, as a "low-level" file manager should be able to work with such long paths. It should definitely warn user that such paths may not work with another applications, when the user is trying to create too long paths... but it is a tool for power users who need this, even for renaming such long path to shorter.
The question is: what other tool should I choose for such tasks? TC? Do you really want to users switch to another file manager just for such simple tasks?
crystalidea
Absolutely agree :(
Even recent Windows 10 preview builds doesn't support long paths to the point we will be able support it in Salamander.
See for example http://stackoverflow.com/questions/1880 ... in-windows or https://windows.uservoice.com/forums/26 ... limitation
It is possible to implement special "long path" panel mode, but it will be limited only to a few operations such as View or Rename.
crystalidea
Jan, was I correct that moving to Unicode would fix it?
It is not connected with Unicode support directly. But we need to rewrite all paths related code for Unicode support and it is a good time to implement mentioned (limited) support for long paths. It is the same place in Altap Salamander code.
autocart
Post by autocart »
Jan Rysavy wrote:But we need to rewrite all paths related code for Unicode support ...
So, don't let yourself stop you from doing it. I almost bought AS but then fortunately stumbled across the Unicode problem in the forums. So, I will not buy it without full Unicode support.
Regards
Stybi
Post by Stybi »
Hmm... What abou this? Too easy?
#ifndef UNICODE
#undef DeleteFile
#define DeleteFile MyDeleteFileA
#endif
void test()
    DeleteFile("C:\\Some\\very\\long\\path");
    DeleteFileW(L"\\\\?\\C:\\Some\\very\\long\\path");
BOOL MyDeleteFileA(LPCSTR path)
    size_t wpathSize = MultiByteToWideChar(CP_UTF8, 0, path, -1, nullptr, 0);
    if(!wpathSize)
        return FALSE;
    LPWSTR wpath = new WCHAR[wpathSize + 5];
    lstrcpyW(wpath, L"\\\\?\\");
    MultiByteToWideChar(CP_UTF8, 0, path, -1, wpath + 4, wpathSize - 4);
    return DeleteFileW(wpath);
Look here: https://msdn.microsoft.com/en-us/librar ... 85%29.aspx
Regards
Altap Salamander could be tested free of charge and it is a good idea to do it because there could be other features you don't like you will not find in this forum :)
-=Majkl=-
Post by -=Majkl=- »
The time has come:
Microsoft removes 260 characters for NTFS Path limit in new Windows 10 insider preview
http://mspoweruser.com/ntfs-260-character-windows-10/
manifested win32 applications
What is a manifested application?
So win64 applications need not apply?
Much less other OS.
Is it [Enable NTFS long paths] only available on the "Server" edition (& not that I know anything about Win10)?
Their announcement was mighty terse.
Windows Store applications
A Win10 "thing"? So hopefully something I will never know about.
"Too long" is one of my biggest bugaboos of late.
I even downloaded TC in an attempt to help work around some of them.
And since we're here, find them in a jiffy, Everything 1.4.0.713b.
path:len:>259 file:
(Modify as needed.)
I have but a handful of (external) manifests.
Everything: ext:manifest
What is a Manifest (in Windows)?
Application Manifest
Looks like it isn't documented (yet). Some info from reddit: see https://www.reddit.com/comments/4lkoe4
<asmv3:application xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
    <asmv3:windowsSettings xmlns:dpi="http://schemas.microsoft.com/SMI/2005/WindowsSettings"
                           xmlns:path="http://schemas.microsoft.com/SMI/2016">
        <dpi:dpiAware>True</dpi:dpiAware>
        <path:longPathAware>true</path:longPathAware>
    </asmv3:windowsSettings>
</asmv3:application>
Another "long paths" thread: http://forum.altap.cz/viewtopic.php?t=32671
