Long Path Support
Andre.Ziegler
Long Path Support
Post by Andre.Ziegler »
In Windows 10 1607 (Anniversary Update) adds support for long paths to eliminate the MAX_PATH issue.
To do this the user had to enable the group policy entry "enable NTFS long paths" under Computer Configuration -> Admin Templates -> System -> FileSystem:
Applications that support long paths must have this entry in the application manifest:
<application xmlns="urn:schemas-microsoft-com:asm.v3">
  <windowsSettings>
    <longPathAware xmlns="http://schemas.microsoft.com/SMI/2016/WindowsSettings">true</longPathAware>
  </windowsSettings>
</application>
Can you set the GPO entry, put this entry in the manifest and test if Salamander works fine with longs paths? If it works, please release a new version.
Re: Long Path Support
(Already mentioned here, Full path too long. Really?)
