How to copy all files from subfolders into one folder?
Is it possible to copy all files from subfolders into ONE folder. I commonly copy photos from a memory card. The camera automatically creates folder with 100 pictures in each folder. I want to copy all these into a 'photos' folder on my hard drive. I can do it by doing a search for *.jpg and then copy the search results, but am wondering if there is a more elegant way, that also allows to me to use 'Move' instead of cut or copy + paste.
Re: How to copy all files from subfolders into one folder?
That's exactly the way I do it right now. Works good enough for meAnonymous wrote:[...]I can do it by doing a search for *.jpg and then copy the search results
Kind regards, KNUT
When I copy from memory card I use copy. When I use move and I have some problem like bad battery or power ... I can lost data.
The same way I use on floppy disc
I mean this is no problem in SW. When You moving data then after moving each file SW must write on medium ! and this may be problem.
What You mean on this problem ?
This is an example where a "branch" (or "flat" or "recursive") view of the files in a folder tree would be useful.Anonymous wrote:Is it possible to copy all files from subfolders into ONE folder.
One would select a folder (or drive), choose "flat" view, and see all subordinate files and folders "flattened" into the panel. Good for visually identifying duplicates, etc., or one could "select all" and copy/move to the other panel.
This feature is available in several SC competitors.
Mouse-centric, Registered
I do this with DOS.
But what's about an improvement of the F5-Copy-Dialog
to exclude folders like:
Copy 13 directories to
C:\Temp\*.*
[x] Files named: [ *.jpg | exclude folders ]
And BTW, the hint to copy folders only should be
in the 'masks hints' dialog , too
i have forgotten him allready
C:\Temp\*.*
AbteriX
