Is it possible to "auto close" the Find-Dialog ?
It's a good thing that the find dialog stays open, but...
Little "interferingly" smts
...often i want simple to "focus" the file i have found again
and than the find dialog could be closed in that case at the same time.
Solution:
If i could hold down the Ctrl-key (or Shift or Alt or...)
while i click on [Focus]
and the find dialog would focus the highlighted file
AND close the dialog for me
would be fine.
What do you think?
Is this an improvement?
Will that be implemented?
Improve Find-Focus behaviour to autoclose
Autoclose for find-window
Sometimes an "auto-close" would be nice
(instead of having some unused find-windows in the task bar
Kind regards, KNUT
