Error on opening some ZIP-files
Posted: 08 Jan 2024, 21:23
by Lothar
Hello.
I have trouble opening some ZIP-files from time to time:
"This file was compressed using a method that is not supported by this version of the ZIP plugin. " :o
My system ---> Altap Salamander 4.0 (x64) / Plugin: 7-Zip v1.31
Is there any way to upate the plugin?
cu,
Lothar
Re: Error on opening some ZIP-files
Posted: 10 Jan 2024, 10:54
Can you show us such ZIP archive?
Posted: 10 Jan 2024, 23:42
Can you rename the zip to abc.zip and try to open it? Do you still have a problem opening it?
Posted: 11 Jan 2024, 17:29
by therube
A zip using PPMd compression algorithm.
factor (test file, ZIP, PPMd compression method).zip
(467.66 KiB) Downloaded 264 times
(7-Zip will open said file.)
Posted: 11 Jan 2024, 19:01
Ok, I am confirming the problem.
