PB38: UnISO cannot open empty ISZ
Forum rules
Seems that UnISO have more problems with isz images. Just tried to create empty image (just open UltraEdit and save dummy file as isz). Then 4x error message says:
UnISO
This package does not contain a data block of HFS Plus partition starting at 51200.
The block is needed for proper handling of the package.
[OK]
Everytime part "starting at ..." is different.
test.zip
(680 Bytes) Downloaded 598 times
For XPiS: please report Preview Build problems in EAP section. I will move this thread.
Re: PB38: UnISO cannot open empty ISZ
Please keep the rule of one issue per thread. Thread split into two.
Raptor wrote:Just tried to create empty image (just open UltraEdit and save dummy file as isz). Then 4x error message says:
Problem solved for the next version (AS2.53b1-PB41/2.53b1/2.53).
