line-number bar in text viewer
nistvan_ro
Hi!
In the text viewer it would be nice if we have a line-numbers bar - to help software developers! Thanks
Re: line-number bar in text viewer
For such special text features I use Scite as alternative Viewer / Editor: small, fast, no installation, text highlighting, and much more.nistvan_ro wrote:[...] to help software developers
Kind regards, KNUT
Yes, for editing text-like files I use other than notepad.exe editor (in my case I use other great Czech editor PsPadKNUT wrote: For such special text features I use Scite as alternative Viewer / Editor: small, fast, no installation, text highlighting, and much more.
I use F3 as a quick view.
We want to re-write the internal text viewer from the scratch. Support for unicode, utf, syntax highlighting, line numbers, caret for keyboard selection, separate it to plugin, etc. It's a very high priority for us, but it will take from 4 to 6 monthsino wrote:But I strongly agree with nistvan_ro to add line-numers bar into the View, because the viewer in Salamander is pretty fast
Jan Rysavy wrote:separate it to plugin
Kind regards, KNUT
nistvan_ro
Probably it would be possible, but I can say that it loads a bit slow if you're using it just for viewing. And I have a P4 with 1Gigs of ram... Still good idea 'though.KNUT wrote:Jan Rysavy wrote:separate it to pluginIs there a possibility to include Scite as a "text viewer / editor" plug in?
It prevents you from rewriting the viewer from the scratch.
Scite (Scintilla) is open source - isn't it!?!?
SciTE is a text editor. Servant Salamander's internal viewer is highly optimized for speed (even on files over 4GB barrier).KNUT wrote:Is there a possibility to include Scite as a "text viewer / editor" plug in?
Nice to hear this since i use F3 often tooJan Rysavy wrote:We want to re-write the internal text viewer from the scratch. Support for unicode, utf, syntax highlighting, line numbers, caret for keyboard selection, separate it to plugin, etc....
Additionally i suggest an search-line as in ListXP too.
http://www.listxp.com/index.html
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
In the meantime, I recommend V... a great text viewer:
http://www.fileviewer.com
It isn't free, but isn't over-priced, either, and has many useful features. Supports EBCDIC!
Don't be put off by the dull screen shots... all colors are adjustable.
Mouse-centric, Registered
That is awesome news.Jan Rysavy wrote:We want to re-write the internal text viewer from the scratch. Support for unicode, utf, syntax highlighting, line numbers, caret for keyboard selection, separate it to plugin, etc. It's a very high priority for us, but it will take from 4 to 6 monthsino wrote:But I strongly agree with nistvan_ro to add line-numers bar into the View, because the viewer in Salamander is pretty fast
Go to line
In the mean time, would it be possible to implement a "Go to line number" function? Even Notepad can do that.
The whole line could be selected to show the exact line.
Groente, Michel.
