AS2.51: Crashing with TortoiseSVN-1.4.8.12137
If you look at displayed bug report to the "Stack Back Trace" section, you will find something like this:
Microsoft Windows XP Professional Service Pack 2 (Build 2600):
Thread ID: 0xF70 (Thread with Exception)
EIP = 0x78138AA0 MSVCR80.dll
0x01A3F407 tortoisesvn.dll
0x004E399B salamand.exe
0x004E3B34 salamand.exe
0x00442034 salamand.exe
0x00442A41 salamand.exe
0x00442AAE salamand.exe
0x23907AF9 SALRTL.DLL
0x7C80B683 kernel32.dll
Microsoft Windows Vista Professional (Build 6000):
Thread ID: 0xB08 (Thread with Exception)
EIP = 0x72578A8C MSVCR80.dll
0x724EF3CA MSVCP80.dll
0x1000F407 tortoisesvn.dll
0x77883833 kernel32.dll
0x77B2A9BD ntdll.dll
This problem was fixed last year in TSVN, but unfortunately it is still not included in latest TortoiseSVN-1.4.8.12137.
Resolution: the solution is install latest TortoiseSVN.
Another way is disable TortoiseSVN icons overlays in Salamander 2.51 by turning off Options > Configuration > Icon Overlays > Display custom icons overlays option.
Disabling Icon Overlays in Altap Salamander 2.51
