"queue" as default
legoxx
"queue" as default
Post by legoxx »
it's really great to see queue feature added, but why not to enable enqueing by default? (it's the most used mode IMHO)
legoxx
cincura.net
Re: "queue" as default
Post by cincura.net »
legoxx wrote:Hi,
legoxx
From my POV I have objections. Sometimes I'm working on a lot of projects (doing some copying/moving on net, local, USB disks, etc.) and turning queueing by default will be contraproductive for me.
I can imagine, that it will be configurable. But not by default turned on.
Jiri {x2} Cincura
May be it would be simple enough if the last configuration change would be remembered. Like a switch - just On/Off - holding the last state.
That could be a thinkable solution. For example, the Pack dialog remembers the 'Delete files from disk after packing to archive' setting (which can be a little surprising after some time not packing).
We have this problem on to-do list.
Meanwhile, look at http://forum.altap.cz/viewtopic.php?p=4096#4096 for Alt+W tip.
