Hidden feature of internal viewer
Klettermaxe
In my opinion Servant Salamander is definitely the 'Swiss Army Knife' among the file managers. I won't miss it!
Yesterday I discovered that in SS Beta 10a (other than in SS 2.0) the internal file manager opens the next file in the panel list if you press the space bar. This seems to be currently undocumented. I wonder if there is also a key for viewing the previous file?
cincura.net
Re: Hidden feature of internal viewer
Yes, of course. Use Shift+Space.Klettermaxe wrote:I wonder if there is also a key for viewing the previous file?
Jiri {x2} Cincura
Klettermaxe
Navigation keys in internal viewer
Thanks a lot for the hint! Internal viewer is even more useful now.
Imho ALTAP should consider using 'Backspace' instead of 'Shift+space' in the final version because Backspace is also used in PictView for viewing the previous file. I cannot see that this key is occupied by another function in internal viewer.
> Yes, of course. Use Shift+SpaceKlettermaxe wrote:Yesterday I discovered that in SS Beta 10a (other than in SS 2.0) the internal file manager opens the next file in the panel list if you press the space bar.
Thank you both. This is a great feature.
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
Raven
Even better...
You can even select/deselect files by INS while browsing with pictview. So you can visually browse through a collection of pictures and mark some of them, e.g. for deletion.
