PictView and transparent PNG Icons
KNUT
Post by KNUT »
Hello!
Pictview does not show the transparent part of a PNG file :(
Try the wounderful "Silk Icon Set" or another transparent PNG file.
- IrfanView show the file correct...
- Perhaps the same problem as with the IE (Google)... :?:
jis
Re: PictView and transparent PNG Icons
Post by jis »
KNUT wrote:Hello!
The same is discussed in the thread (polo)průhlednost PNG souborů v SS in the Czech part of forum.
Updated version of PictView for Servant Salamander is here: http://www.pictview.com/salamander/.
INFO: Updated PictView (English, German) for download
KNUT
Post by KNUT »
jis wrote:Updated version of PictView for Servant Salamander is here: http://www.pictview.com/salamander/.
I already use the new PictView Version 2.01 :?
Kind regards, KNUT
Datalog
Post by Datalog »
AFAIK it's not implemented, yet.
Transparency works in icons, thumbnails mode, only.
jis
Post by jis »
Datalog wrote:AFAIK it's not implemented, yet.
I think too that this new version corrected only thumbnails generation in Salamander panels.
I miss support for alpha channel too. Especially 32bpp PNG and XP icon files.
KNUT wrote:Pictview does not show the transparent part of a PNG file :
I'm sorry I should have been more specific when wriiting 'Please remember that alpha-channel is still supported only when thumbnailizing strictly 32bit images'. Indeed, the alpha-channel is correctly processed only for 32 bits-per-pixel ICO and PNG images and only in the thumbnail mode of Salamander panels. Not yet in the viewer. But it will definitely be fixed for Beta12.
--- Jan
KNUT
Post by KNUT »
Jan Patera wrote:But it will definitely be fixed for Beta12
TIA :D
Kind regards, KNUT
