FLAC Viewer Plugin
- stepand76
FLAC Viewer Plugin
FLAC Viewer is plugin for view meta information on FLAC (Free Lossless Audio Codec) files.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
- stepand76
Version 0.2.0 (28.1.2009)
[+] Texts moved to SLG file (now it is possible to translate plugin to other languages).
[+] Added version information (VERSION_INFO) into plugin binnary files.
[+] Added plugin icon and icon of viewer window.
[-] Fixed placement of viewer window.
[-] Fixed showing of message dialogs (icon, set of buttons).
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
- stepand76
Verze 0.3.0 (4.2.2009)
[+] Added compatibility with AS 2.52 beta 1.
Legend
[*] Change
[-] Bugfix
Re: FLAC Viewer Plugin
Thanks for the plugins.
It seems, that they don't work anymore with 2.52 beta 2 (JSON and Flash neither)
even though it's noted in the release notes:
Thanks for any update.Altap Salamander 2.52 is now backward compatible with plugins for versions 2.5 and 2.51.
- stepand76
Version 0.4.0 (24.8.2009)
[*] Fixed compatibility with AS 2.5, 2.51 and 2.52 beta 2.
[-] Fixed Alt+Space navigation in viewer.
[*] New view style (requested by ether).
Legend
[*] Change
[-] Bugfix
Great, thank you.
Eric
Eric
- stepand76
Version 0.5.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
Legend
[*] Change
[-] Bugfix
- stepand76
Version 0.6.0 (4.3.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
[+] Added an option to save possion and size of viewer's windows.
[+] Added an option to prefer keyboard shortcuts in main menu.
Legend
[*] Change
[-] Bugfix
- flacviewer_0.6.0.zip
- (765.83 KiB) Downloaded 964 times
I'm getting a very strange bug with the latest version of the plugin (on any file i try to view tags for):
it looks like the delimiters aren't read correctly or something, so the tags aren't properly divided into sections for display.
I've attached a screenshot of the proper tag in aimp and what I get in 0.6.0
- Flacview 0.6 - def not ok
- flacvfail.png (18.3 KiB) Viewed 29368 times
- Aimp2 screenshot (ok)
- aimpok.png (11.72 KiB) Viewed 29368 times
- stepand76
Thanks for the report. I will look on it.svyr wrote:I'm getting a very strange bug with the latest version of the plugin (on any file i try to view tags for):
- stepand76
Version 0.6.1 (11.3.2010)
[-] Fixed reading of metadata.
Legend
[*] Change
[-] Bugfix
- flacviewer_0.6.1.zip
- (765.92 KiB) Downloaded 987 times
Thank you for the quick fix ! Tested and looks to be working.
plz update this to the latest beta
