Bug report: Can't delete folders under mount points
Posted: 28 Dec 2005, 05:29
I have two hard disks - the My Documents folder is a 'mount point' for the second drive. In other words I have two disks but one C: drive.
When I browse anywhere under My Documents, I am unable to delete any folder. Files can be delete ok.
The error message is Cannot delete XXX: Access is denied.
I can delete the directories fine from Explorer.
I'm using Salamander 2.5 beta 10a. I think it has a problem with mount points.
