Is 7-Zip Plugin a single product?
carolecao
I want to know whether the 7-Zip plugin from ALTAP is a single product or can only be used when I install Servant Salamander . Thank you very much!
The plugin is related to Salamander and works only (<?>AFAIK) with Salamander.
But 7-Zip itself is an own application and can be found on the net, e.g. at http://www.7-zip.org/
HTH?
HTH?
AbteriX
