Saving FTP details
Steve2106
Saving FTP details
Post by Steve2106 »
Hi There,
Everytime there is an issue with Salamander and I repair, I loose all my ftp site settings.
Is there a way to save them and re-import when I need to.
Thanks for your help.
Best Regards,
Steve.
Re: Saving FTP details
I did not investigate. Since Salamander saves everything into windows registry I would search for that there.
You can backup and re-import whole Altap Salamander configuration: http://www.altap.cz/salamander/help/sal ... iguration/
Note: there is some problem with your Windows, it should not kill Salamander while it is saving configuration.
Steve2106
Post by Steve2106 »
Hi There,
Thanks for the replies.
I have saved the configarations but when I import there are no ftp details saved only my plugins.
<< Note: there is some problem with your Windows, it should not kill Salamander while it is saving configuration.
This is not the issue. Salamander came up with a message saying something is corrupted and it should delete whatever (can't remember the exact message). When it had deleted and restarted all my ftp details had gone.
If you look back in your correspondence from me you will see that I have had this issue before.
Still love the program though.
Best Regards,
Steve.
