Quick Type to File With Any Character
Posted: 27 Feb 2015, 22:39
by dprice
I know you can quickly type to a file by typing the first letter of the filename, but it there an option to type to any character within a filename?
Thanks,
Derek
Re: Quick Type to File With Any Character
Posted: 28 Feb 2015, 17:13
by therube
Use the / key.
So /man will find "chrome.manifest".
Or /ug/c will find "plugin-container.exe" but not "plugin-hang-ui.exe" (as there is no 'c').
Posted: 02 Mar 2015, 02:45
by dprice
Thanks! Once again Altap Salamander FTW!
Posted: 08 Mar 2015, 09:57
