Extend user menu with 'folders' [SOLVED]
crystalidea
Post by crystalidea »
User menu has become too long in my case - it doesn't fit the toolbar and the list is quite long.
Why not to extend user menu with 'folders'?
Re: Extend user menu with 'folders'
Hi dufreyne
Are you talking about Submenues? They already exist. Only disadvantage: no drag'n'drop possible to entries in a submenu. And also: can's set an Icon for it. With text labels turned off you'll have to hover to identify it.
crystalidea
Thanks for the answer. My mistake, it's there.
