Eroica Viewer
HansueliHof
Eroica Viewer
Post by HansueliHof »
Hi
I've seen you do not include Eroica Viewer in the new version due to licensing problems.
Is there any possibility I can get / buy Eroica viewer somwhere and include it into Salamander?
I would not mind paying for it.
Thanks
Hansueli Hof, Basel hansueli.hof@bluewin.ch
McLion
Re: Eroica Viewer
Post by McLion »
You should look into using oilister instead. It's much more powerful and shows you the later office file formats as well.
Search this forum and get back here if you can not get it to work.
Re: Eroica Viewer
I think that the problem is more that Eroica is not developed/supported anymore.
Re: Eroica Viewer
