Hello all,
Is there any driver for Ext3 / Ext4 linux file system developed as a Salamander plugin so that it can read and write MicroSD formatted by for example an Android device?
Introduce me if any.
Tx
Driver request for Ext3 & Ext4 file system
Re: Driver request for Ext3 & Ext4 file system
You can allways install the Ext2 FS driver for windows. http://sourceforge.net/projects/ext2fsd/
This has nothing to do with Salamander. Its a system driver.
Thanks for the reply.
The reason I am interested in using plugin is to be economic in terms of my PC memory and not to occupy it with programs I use occasionally. Do ext2fsd drivers slow down the system ?
I am not aware of any slow downs caused by the ext2fsd driver.
If you want to speed up your system, install a SSD drive.
read only option - DiskInternals Reader for Total Commander (freeware):
http://www.diskinternals.com/reader-for-tc
- it is a native reader for: Ext2/3/4, ReiserFS/Reiser4, HFS/HFS+, UFS2, NTFS, Fat/exFAT, virtual disks (VMware, VirtualPC, VirtualBox) and more...
- admin privileges are required
- use it via the Manison's tcproxy plugin
Thanks for the answers
Awesome but Paragon is not free!
@SelfMan I have been trying your recommended for a while and I am satisfied with it
Thank You.
ext2fsd
