Cannot open any file
Posted: 17 Dec 2014, 19:52
by nashraf
I cannot open any file directly from your window e.g. if I have a word document and if I double click on that to open in MS-Word. I get the document open in MS-Word but I also get Office Reinstall screen (see attached capture.jpg file) which I am not getting if I don't use your software. Second, example if I have a file with sql extension then this file should open in SQL Server which I have installed on my machine but I am getting a message (see attached sqlCapture.jpg file).
Is this is a known issue or do you have any resolution for this?
My machine:
Windows 8.1 64bit
MS Office 2013
SQL Server 2014
Re: Cannot open any file
Posted: 18 Dec 2014, 17:50
by therube
Will the same file open successfully when clicked on from Windows Explorer?
Is Office "installed" on a network drive?
AFAIK, not that I know anything of Office, I don't think you can run Office across from a network drive?
You can open a doc stored on a network drive in a locally installed Office, but not vice-versa.
Posted: 18 Dec 2014, 21:46
by nashraf
I have this explained in my question that I am not getting this issue if I don't use your software. Secondly, this is not a network path issue because even If I try to open from my computer C: drive I am getting this the same issue.
Posted: 19 Dec 2014, 12:52
by mdruiter
Do you run x86 (32-bit) Salamander on a x64 OS, by any chance? Or is Salamander elevated? Or started in some compatibility mode?
Your problem sounds very specific to your installation. I think you should ask your system administrator to have a look.
Posted: 22 Dec 2014, 21:48
by nashraf
I uninstalled x86 version and installed 64bit version and everything is started working like a charm!
Thank you very much!
