Directory Compare by size/content (ignore name) won't sort
uidaltap
Post by uidaltap »
I rename my files like I rearrange my home office ---> much too often!
Commands > Compare Directories forces "with same name"
Commands > FInd Files and Directories >
- Named *.*
- Look in e:\Lots_of_BackUps
- Check Search file content -
- Check Search subdirectories
- Commands
- Find Duplicate Files
- Uncheck Name; Check Size and Content
- OK
- Salamander finds them and groups the duplicates together
and uses shadows to differentiate the groups
??????????? Click on Path doesn't work
??????????? View > Sort by Path is BLOCKED
- Cursor back up to "Look in" and enter one of the subdirectories:
e:\Lots_of_BackUps\Last_Month
- Commands > Refine - Subtract from Found Items
??????????? REMOVES THE ENTIRE LIST !!!!!!!!!
??????????? The manual suggests that is how you search
for cars and then limit to john within cars.
>>>>>>>>>>>> How do I get rid of the duplicate files
in the directories ????
>>>>>>>>>>> I'm trying to find SORT BY PATH, so I can
just scroll though and block delete.
>>>>>>>>>>> My backups have 250,000+ files, so the a manual click
on each box is not an option!
I'm hoping there is a solution in the Vers 3.0 I purchased today.
Any ideas? Thanks
Re: Directory Compare by size/content (ignore name) won't so
While Salamander is very good at much, it only provides very basic duplicate file handling, IMO.
Two very good, full featured duplicate file finders:
Duplicate Cleaner (free version is most likely sufficient).
AllDup (free)
