Salamander 3.03 remote desktop
frax
Post by frax »
Working locally everything works fine, but there is one little annoyance when I access this machine (Windows 7 Urtimate, running Salamander 3.03 64-bit) - ctrl-alt-insert, which copies the path of the current panel to the clipboard, doesn't work.
AltGr-Insert works though...
Hugo Ahlenius
Re: Salamander 3.03 remote desktop
Hi frax,
I am pretty sure this is an issue with mstsc (the remote desktop client).
Just do not leave the remote desktop using quick task switch (Alt+Tab).
When it's broken, just reactivate the client, then leave it by some other way other than Alt+Tab and everything works as usual again. At least that's what I have found.
Full screen or windowed mode?
I only ever had problems with this switching from remote to local in window mode. (I always keep the default mode so that Alt+Tab is consumed remotely in full screen mode.)
frax
Post by frax »
I am seeing this in full screen. I tested, and AutoHotkey can receive that keyboard shortcut without problem (in remote desktop, on the server, when full screen).
Hugo Ahlenius
