Automatic sorting (e.g. on Create new folder)
Posted: 23 May 2006, 18:07
After creating a new folder (or unpacking an archive) the folder tree updates itself automatically according to the applied sort specification (by name, by date etc.).
Now, sometimes this is a nice thing to have, but most of the time iI just prefer for the newly created folder or unzipped archive to be added to the end of the tree and updated after an explicit refresh. That allows me to unzip an archive create a folder and quickly select the unzipped files and move them into the folder. Depending on the naming scheme of folders and files it can be a cumbersome process to select all the files to move because they are automatically sorted and soemetimes mixed with other files.
Is there any way to turn the automatic update feature off? If not...feature request.
schroeder
schroeder
