Using the 2.5b10a, I'm using the FTP plugin and have the save password box checked. The password is indeed saved and everything works fine, until I use the "list of working directories (ALT+F12)": if I choose a ftp directory there, it will ask me again for the password, which it should not.
Thank you,
Arnaud-
						FTP keeps asking password in list of working directories
Re: FTP keeps asking password in list of working directories
Yes, we plan to fix this problem. It means to use bookmark identifier in FTP path rather than classic URL. WinSCP plugin already works this way, we will use the same approach.
