I noticed when you use the batch renamer, the mixed case does not seemed to work correctly. For example, if I rename "I'll be there.txt". It would change to "I'Ll be there...".
Would you mind having a look?
Batch Renamer: mixed case doesn't work correctly
Madison
Batch Renamer
I believe the renamed file should be "I'll Be There.txt" and NOT "I'Ll Be There.txt".
Am I missing anything?
Cheers,
Madison.
Cheers,
Madison.
Re: Batch Renamer: mixed case doesn't work correctly
This confused me...Anonymous wrote:It would change to "I'Ll be there...".
Now the Batch Renamer considers all non-alpha characters to be separators. Not a bug, just feature.
Madison
Batch Renamer
Hi Jan/Mem,
I agree on the technicality and thanks for the response, but it still does not make sense from practical stand point.
Normally, when one would capitalize "i"ll", one would probably expect to see "I'll". I actually had to use a different program to achieve my purpose but I really like your product. It is addicting.
Any chance you guys can fix this to meet a common user's expectation? Or add an option to add multiple separaters (would be ideal).
Thanks,
Madison.
Thanks,
Madison.
there's related post to this in the czech forum over here.
basically, it would be nice to have configurable separators, which would be used in these functions / dialogs:
example list: XviD,DJ,MIX,VA,DJs,I,II,III,IV ...
- change case command (mixed case, partially mixed case)
- renamer plugin (mixed case)
- quick rename dialog (cursor stop locations on ctrl+left/right etc.)
