Find Files inside compressed files. (ZIP, CAB, etc.)
jderr
Post by jderr »
I needed to search for a file inside a CAB file the other day and had to use XP's native search. (Hate it). A nice addition would be the option to search inside support archive files.
Stefan
Post by Stefan »
Yes, i had suggested this behaviour too.
Would come very nifty to have this.
Stefan
Pleased user since v1.52        -   Licence# 0306-0046-01
cincura.net
Post by cincura.net »
I think it's not so easy. For example to get list of files in tar.bz2 you need to unpack nearly the whole archive. Next example with password protected RAR (with password protected list of files).
For small files, it can work on-the-fly, but with 300MB tar.bzip, ouh. Maybe will be a good idea to do this via plugin with some extended setup options.
Jiri {x2} Cincura
Stefan
Post by Stefan »
If i select the archives to search i must know what i do.
If i search from the root of my 300GB HDD i must know it too :wink:
For password protected archives there could be an dialog box like
"Enter password [        ] [Skip] [Skip all] [Cancel]"
Stefan
cincura.net
Yes, I know, I was just thinking aloud and chalking out the problems and ways of solution.
Jiri {x2} Cincura
Stefan
Post by Stefan »
cincura.net wrote:Yes, I know, I was just thinking aloud and chalking out the problems and ways of solution.
Thank you. All suggestion/discuse are highly welcome.
Stefan
ALTAP Roadmap - Support for nested archives, searching in archives.
Georgd
Post by Georgd »
cincura.net wrote:For example to get list of files in tar.bz2 you need to unpack nearly the whole archive.
To meet this problem, we could have 2 checkboxes: "search in archives providing file list directly" and "search in archives that have to be unpacked to obtain file list" (of course a better wording, it's just about the meaning ;) )
/Georg
Using Salamander since v 1.52
Georgd
Re: Find Files inside compressed files. (ZIP, CAB, etc.)
Post by Georgd »
"Find Files inside compressed files" is not any more on the roadmap http://www.altap.cz/salamander/roadmap/ :(
Did anyone find a good workaround? I do manually unpack all archives to a temp folder, search there, then delete the temp folder - not really nice...
Georgd wrote:"Find Files inside compressed files" is not any more on the roadmap http://www.altap.cz/salamander/roadmap/ :(
Yes, using the Automation plugin.
Georgd
Post by Georgd »
tukanos wrote:Yes, using the Automation plugin.
Sounds interesting. I don't find such a script in my Salamander installation - could you please point me to a download page?
Well, if the pre-installed scripts do not cover your needs, you will have to write your own.
Here is what is pre-instlled:
To write your own plugin search for automation at http://www.altap.cz/salamander/help/
