Macintosh Filenames
Posted: 22 May 2014, 10:54
by magenta54
when having Files on the harddisc coming from Apple Macintosh collegues the Umlauts are from the Mac Codepages. When the normal Explorer you can work with such files, with Altap Salamander you can't. System tells "cant find that file".
e.g.
ÄnderungenInfrastruktur2014.docx
Can you fix that with one of the next updates?
Re: Macintosh Filenames
Posted: 22 May 2014, 11:17
We plan to implement Unicode, it will solve this problem.
Posted: 28 May 2014, 14:28
by blue.bear
When are you planning to release next update?
________________________________________________________
wniosek o dotacje unijne, car lpg conversion, weight loss methods, bilety autokarowe, krakow
Posted: 29 May 2014, 09:21
We have no ETA for Unicode version, we are still working on AS 3.x.
Posted: 20 Jun 2014, 09:34
by mklhmnn
magenta54 wrote:Hi,
e.g.
Just curious: how do you get these files on your disk? By checking out from a version control system? Then you need to be aware that on OS X umlauts are stored as two characters, in your case one for A and one for the two dots. That way you can create a new file on Windows in the same directory that looks the same but has a different character/byte sequence! Supporting unicode alone does not solve this problem.
