Unpacking to archives or plugin file-systems
Posted: 14 May 2014, 13:03
by crystalidea
Hello, I see this error message for years, any chance to implement it? Doubt it's technically difficult
Copy Error
Unpacking to archives or plugin file-systems is not supported yet.
[OK]
Re: Unpacking to archives or plugin file-systems
Posted: 18 May 2014, 23:03
by Ether
Actually, it's not that simple, if it's to be done right. If done simply, the user interface and performace could be bad.
Posted: 18 May 2014, 23:45
Implementation of this feature would be very difficult.
Posted: 20 May 2014, 20:11
by crystalidea
Ok, yes is hard if not just to extract to temp folder and move to destination.
Any plans on implementing this correctly?
