How to set color filter by date?
Michael Lu
Post by Michael Lu »
For example, I want to set color for files modified in the last some days. Does salamander has this feature? It seems now I can only set color for files by file types.
Re: How to set color filter by date?
It is not supported but looks easy. Where did you see this feature? Is anyone else interested?
Note: There are other options in the Find > Advanced dialog box such as file size or time range:
Michael Lu
Totalcmd has this.
blue.bear
Post by blue.bear »
Nice feature. I'll gladly test it.
