I don't have a problem with PDF Thumbnails (there was one topic here), but the regular F3-Preview of PDF documents doesn't work at all any more with v3.0, is there a reason why?
Kai
PDF Preview doesn't show up any more
Re: PDF Preview doesn't show up any more
Do you use x64 version of AS 3.0? x64 version of Eroiica Viewer (PDF viewer) is not included in AS 3.0, we have it on Roadmap.
Yes, thanks. Its the x64 version. Do you have an imagination when it will be ready?Jan Rysavy wrote:Do you use x64 version of AS 3.0? x64 version of Eroiica Viewer (PDF viewer) is not included in AS 3.0, we have it on Roadmap.
Why did you remove the 2.54 downloads? Is it availlable somewhere?
Kai.
Note: x86 version of AS 3.0 does include Eroiica Viewer plugin. See AS 3.0 Changelog for more information.
We don't know time for x64 Eroiica Viewer release, it doesn't exist now and it is not 100% clear it would be possible to implement. We will try...
You can download all old Altap Salamander versions from Download page, click Previous Versions link. Read index.txt for files description.
